Rectifier circuit
Discussion in 'General Electronics Chat' started by sumitest, Mar 14, 2016.
  1. sumitest
    Mar 14, 2016
    hello everyone,
    I have made full wave bridge rectifier circuit using IN4007 diodes. As per the theory we all know if my input voltage is below the threshold of the diode it will not conduct but in my case I'm using signal from function generator if I give 4V rectifier is working very well but it is also conducting when supply is 1V only. I don't the reason pls help me out from this problem.
    Mods Edit:
    Please don't do double post again, now they were merged to one thread.
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,688
    1,297
    Look at the 4007 datasheet for the value of Vf, the forward conduction voltage. there probably is a range of values and it will say what the test current was. there also might be a plot of the forward voltage versus current. From all of this, you should be able to see what the minimum Vf is, and that it is less than 1 V.
    ak
  3. recklessrog
    Member
    May 23, 2013
    346
    102
    How are you measuring the voltage? if you use an RMS meter, remember that the peak voltage is 1.414 times the RMS so your diodes will just be conducting on the peaks.
  4. sumitest
    Mar 14, 2016
    i'm measuring using oscilloscope
  5. sumitest
    Mar 14, 2016
    The forward voltage drop is 1v and since I'm using it in full wave bridge rectifier configuration so it might be around 2V but still when supplying voltage is 1 v diodes are conducting
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,271
    224
    If you don't draw any appreciable current (e.g. just a meter), wierd things happen.
  7. wayneh
    Sep 9, 2010
    12,381
    3,236
    I agree. Add a 1K resistor as a load and see what happens.
  8. crutschow
    Mar 14, 2008
    13,492
    3,372
    The forward drop of a junction diode is not fixed but is a logarithmic function of current.
    Thus at low currents the forward drop is much less than a volt.
    Here is the typical characteristic of the 1N4001-1N4007 diodes:
    The curve deviates from the logarithmic curve above 1A due to the intrinsic resistance of the diode.
  9. wayneh
    Sep 9, 2010
    12,381
    3,236
    I assume he's seeing TWO diode drops in his measurement, i.e. 0.5V each, which is not terribly surprising with µA current.
  10. ian field
    Oct 27, 2012
    4,447
    791
    Everyone else has pretty much covered it, I would add that a function generator can be cranked up far too fast for standard recovery diodes like the 4007.
    Anything above a few kHz and you might do better with the UF400x series.
