rectification
Discussion in 'Homework Help' started by benjazzy, Jul 9, 2010.
  1. benjazzy
    Apr 1, 2010
    6
    how do i step and rectify a 240v ac to 5 or 6v dc
  2. BMorse
    Sep 26, 2009
    2,675
    234
    with the use of a transformer, bridge rectifier, and a voltage regulator (+ a few other components, such as a fuse, etc.)..... or buy a wall wart that will give you the proper voltage output that you need.... much easier and safer for beginners.....
    B. Morse
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    As BMorse said, "wall warts" or plug supplies are a great way for beginners to get a safe and inexpensive power supply started. Many are not regulated. If you find one that's rated for 9v-12v at 500mA to 1A, you can add a couple of capacitors and a 7805 fixed voltage regulator with a heat sink attached to make a very cheap 5v regulated supply. It won't be terribly efficient, but it will work.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    I moved the post to the home work help.
    I got this in an e-mail:
    I do not answer in e-mails.
    Here is a page of the EDUCYPEDIA on powersupplies:
    http://www.educypedia.be/electronics/circuitssupplies.htm
    There you will find a lot of information in the links.
    As it is home work, can you show us what your plan is?
    Bertus
