Rectangular loop in magnetic field
Discussion in 'Physics' started by ivepoli, Apr 22, 2016.
  1. ivepoli
    Apr 19, 2016
    I don't understand why the loop rotates.
    Here's my probelem:
    F is the torque twisting the loop. According to right hand rule, the two Fs always point in the direction shown above. Thus when they have twisted the loop so that its plane is perpendicular to B, the two Fs still point that direction. I don't understand why the loop continues to rotate (in clockwise direction).
  2. SLK001
    Nov 29, 2011
    852
    243
    Maybe the current in the loop is reversed when the loop face is parallel with the magnet faces - like a motor. Without the current reversal, it would act like a D'Arsonval meter movement.
  3. profbuxton
    Member
    Feb 21, 2014
    233
    68
    You did not show the commutator which will switch the current to the next loop(not shown ). Real motors have multiple loops and commutator segments.
  4. ivepoli
    Apr 19, 2016
    All of textbooks I've read don't mention the reverse of current. I found this text helpful:
    https://www.boundless.com/physics/t...urrent-loop-rectangular-and-general-561-6351/
    However, it still doesn't explain the point about rotation. It says the mechanical energy from rotation is used to power another device. It also explains the reverse of torque when θ is negative, but it doesn't say anything about the reverse of current. So it means the loop can't rotate more than half of rotation. Then why the set up can be used to power another devices?
    I think the key here is only the current switching like you said. If it's true, why don't textbooks show it to readers to clear the misunderstanding?
    Here's a video simulation:
  5. wayneh
    Sep 9, 2010
    12,405
    3,256
    Just speculation - I suppose the authors believe it's important for the student to grasp the forces involved and how they can produce mechanical shaft work. Understanding the actual operation of a motor is not the goal. Introducing the switching might satisfy the curiosity of students like you that need to see the full picture, but would hopelessly confuse less astute students. It would dilute the main points. My 2¢.
  6. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Wikipedia is your friend! Search for dc motors.
