Rectangular coil calculation
Discussion in 'General Electronics Chat' started by upand_at_them, Aug 19, 2016.
  1. upand_at_them
    Thread Starter Active Member
    May 15, 2010
    246
    29
    For my own education/entertainment, I'm interested in building a RFID reader. But I'm having a problem with a reference to the formula for a rectangular inductor.
    This page: https://courses.cit.cornell.edu/ee476/FinalProjects/s2006/cjr37/Website/index.htm
    ...refers to a variable "b", which is defined as "the width across the conducting part of the coil". I don't understand what that means, since the entire coil conducts. And I couldn't glean the information from that page as their value of 0.3 cm doesn't seem obvious in any of their pictures. What am I missing?
  2. OBW0549
    Mar 2, 2015
    1,389
    932
    I think the "b" parameter is simply the thickness of the bundle of wires in your coil.
  3. upand_at_them
    May 15, 2010
    246
    29
    I'm pretty sure the thickness of the bundle of wires is represented by variable "h", "the height of the coil". "b" seems to be something else.
  4. upand_at_them
    May 15, 2010
    246
    29
    Great, thanks! Sorry, OBW, if that's that you were referring to. It didn't hit me right away that the bundle has two thicknesses.
  5. DGElder
    Member
    Apr 3, 2016
    347
    87
    If you laid the coil flat on a table, b (T in the formula below) would be the height. h is the thickness or width of the bundle. The linked blurb with drawing gives a clear definition.
    Formula units are microhenries and inches.
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwihhKmX8c7OAhWGMSYKHZYVAr8QFgghMAE&url=http://www.minco.com/~/media/Files/Minco/Instructions/Flex%20Circuits/Technical-Specification-FC01.ashx&usg=AFQjCNHKUUHgGN8YZAVNcq9TLrGvTbYYPw&sig2=PiO_kAOiU6iFErG92gtMDQ
  6. upand_at_them
    May 15, 2010
    246
    29
    :thumbs up:
