Colleagues,
Im working on a small device, whose purpose is to produce 8W IR pulses with IR LEDs. Each pulse is 100us long. The pulses are produced only when the device is in proximity of the target. The proximity is established by the IR proximity sensors* (SFH9201 made by Osram). The proximity sensor consists of a small IR LED, a phototransistor and a 20k pull-up connected to the collector. Part of the 8W IR reflects into the phototransistor and saturates it. The problem is that it takes the transistor more than 1ms to come out of saturation, after the 8W IR is turned off, and I cant make proximity detection during this time. To deal with this problem, Ive connected the pull-up to the digital output of the PIC and drove the pull-up low, when 8W IR was on, then drove it high to make a proximity detection. The phototransistor was still saturated for 1ms. Why does it take so long to recover? Why does it saturate when the collector is pulled to the ground?
I can upload the schematics and waveform, if anyone wants to take a look.
Thanks,
- Nick
* This part of the design was inherited. If the device will be redesigned, it will probably get a capacitive proximity sensor.
Thanks,
- Nick
