Recovering line loss
Discussion in 'General Electronics Chat' started by David_DCSA, Jul 6, 2004.
  1. David_DCSA
    Jul 6, 2004
    Theoretically, would it not be possible to run a conductor in parallel with a commercial power line and make use of the EMF that is normally lost as radiation of magnetic field into space by inducing it into the parallaled conductor and attaching it to a load??
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hi
    Yep, in theory. When you talk about power transfer, though, you need a resonant structure. Considering the wavelength of a 60 Hz wave, it gets a bit unwieldy. Plus the power company is going to notice and demand payment for any power you manage to grab. All the enchroachment on the right-of-way will be a problem, too.
    Good luck, by the way - Nicola Tesla used up a lot of money trying to broadcast power, and essentially proved it was impractical.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    :lol: I did a similar study in Electromagnetics where a closed circuit is created parallel the conductor and its actually quite a successful method, particularly if you can minimise the length of wire that runs orthoganal to the transmission line. I wouldn't advise you to do it, however, as it is illegal!
  4. js_530
    Mar 4, 2004
    8
    Why is it illegal? Or is it illegal if the coil is on the power company's land?
  5. mozikluv
    Jan 22, 2004
    1,437
    hi,
    that's because you are deriving electric power from their power lines. simple as that and besides are you going to pay whatever you get?
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Mozikluv has basically got it in one. You are generating your voltage from the magnetic field produced by the transmission line - in a strange technical sense your actually in contact with the transmission line, absorbing something directly from the transmission line. In a more common sense you are generating a voltage from power loss in the transmisson line which is paid for by someone - this is classified as theft.
