Recording Module
Discussion in 'General Electronics Chat' started by Dritech, Feb 22, 2014.
  1. Dritech
    Sep 21, 2011
    756
    5
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    You think correctly, you need the amp & speaker. One fast way to get there is to use an amplified speaker made for a PC: just use the one speaker with the power cord and loose the other.
    A pair of jumper wires from the speaker's audio input jack to the speaker on your playback unit can be played with to find the proper connection.
    However, there is a limit on how good the sound will be out of the recording unit. The max 12K sample rate is less then music needs. Voice should be fine but it's not a "hi-fi" design, so "try it and see."
    Dritech likes this.
