Recommendation for 3.7V to 5V/12V dual-output step-up IC?
Discussion in 'The Projects Forum' started by summersab, May 5, 2016.
  1. summersab
    Thread Starter Active Member
    Apr 8, 2010
    134
    I'm needing a dual-output IC that will step up a 3.7V lithium battery to 5V (6V if possible) @ 2A and 12V @ 200mA. I'm trying to power a small vibrating motor rated at 5-6V and a small clock that requires 12V. I've found several ICs that will do either 5V or 12V (such as the MC34063A), but I'm having trouble finding a dual output in a single package. Most of the dual-output chips I'm finding are pretty low current. The 12V output doesn't need a lot of current, but more is definitely better for the 5V output since it is driving the motor. I feel like I'm asking for someone to Google things for me, but perhaps my DigiKey/Mouser filter skills are sub-par because I'm having trouble finding something that fits the bill.
    Thanks a lot!
  2. Dodgydave
    Jun 22, 2012
    5,161
    772
  3. summersab
    Apr 8, 2010
    134
    Yeah, I was actually looking for pre-made modules if possible, so your response is perfect. However, yikes - I can't find any that aren't super expensive (like $25+)! Maybe I'm missing something? Perhaps I should stick to separate ICs/boards for each voltage...
