Recommend me a Transformer
Discussion in 'Electronics Resources' started by bassplayer142, Jul 18, 2010.
  1. bassplayer142
    Thread Starter Active Member
    Jan 2, 2007
    89
    I'm not to educated on the terminology of transformers but I'm looking for a standard US 120V step down to 24Vp-p with a center tap. In other words, it will give a positive 12V and negative 12V with respect to the center tap. It needs to be able to draw at least 2Amps. Thanks for any suggestions for inexpensive transformers!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Digi-Key part # HM547 is 24 VAC CT @ 2 amps. it's $21.60 - not bad.
  3. bassplayer142
    Jan 2, 2007
    89
    Are transformers usually that expensive? I was looking for less than $10. I suppose I could try to find a used one and go through all the trouble but I'd rather not...
  4. bassplayer142
    Jan 2, 2007
    89
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It should work just fine.
  6. sceadwian
    Jun 1, 2009
    499
    37
    The problem with transformers is they're made from a lot of wire, copper wire... Copper is quiet expensive as a metal. The higher the amperage required the more the transformer is going to cost because the wires will have to be thicker.
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    Currently shown as out of stock but I've found that by calling around to your local stores you can usually find one that has one or more in stock sitting in the back room. I tried their "Find in store" link for around me and there are 4 stores that show stock.
    http://www.radioshack.com/product/index.jsp?productId=2102703
