Recommend a current sensor?
Discussion in 'General Electronics Chat' started by fastwalker, Aug 13, 2009.
  1. fastwalker
    Thread Starter Active Member
    Jun 24, 2009
    38
    Hi All,
    For my project here I need to measure DC current going to a number of motors, max. would be about 10A each. The measured values will be sampled by a NI Labview setup. Can anyone recommend a fairly inexpensive hall
    effect or other type of sensor that I could use to measure the current going through the power wires?
    Thank you to any responders,
    FW
  2. AdrianN
    Apr 27, 2009
    97
    What is the maximum voltage on the DC power lines?
  3. fastwalker
    Jun 24, 2009
    38
    The pump I'm using takes 24V.
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    How about a resistor? Can't beat it for price.
    John
  5. peranders
    May 21, 2007
    87
    The are quite nice current sensors out there suitable for NI cans. You can use these google words "current sensor dc".
  6. AdrianN
    Apr 27, 2009
    97
    You can use a 0.005 ohm resistor and a current shunt monitor like the INA214 family from TI. This family has a common-mode voltage of 26V.
    The INA214 family are differential amplifiers. You can read about a power supply current measurement and common-mode voltage, as well as errors, in this article:
    The Differential Amplifier Common-Mode Error – Part 2 - Power Supply Output Current Measurement with a Differential Amplifier
    Since the INA family has integrated matched resistors you don't need to be concerned about the common-mode errors.
  7. someonesdad
    Jul 7, 2009
    1,585
    141
    I second jpanhalt's suggestion of a shunt resistor. The only catch is that you need a differential input unless one side of the resistor is tied to ground. Use about a 1/2" long chunk of 16 gauge Nichrome wire and you can make your own 0.01 Ω resistor that drops 100 mV at 10 A (it will be dissipating 1 W at 10 A, so it's gonna be warm).
  8. AdrianN
    Apr 27, 2009
    97
    The alternative is to buy one from Digikey ($0.5 ... $2).
  9. fastwalker
    Jun 24, 2009
    38
    Thanks guys, excellent responses. I think I'll try using a simple shunt resistor.
    Thanks again,
    FW
