Yes and the power specifically is coming from this box, that power is a 10V/2.5mA, (25mW), using that power I need to get it to 16 of them. Therefore, I need a voltage follower. Please list your favorite op amps that can do the job.
Unfortunately a switch will not due, because he wants to measure all of them at the same time, not switch through them. And having all connected to that channel (the 10V/2.5mA channel) would load down the box obviously.Sounds like you need to multiplex them with CMOS analogue switches.
Unbuffered from the 4000 CMOS family might do - but the RDSon could be a problem, and your signal mustn't exceed Vdd.
Other than that - there's whole families of industry standard analogue switch ICs that should provide a part that doesn't degrade signal integrity.
Since your input does not provide a sink for the 2.5 mA of current, will the input still be +10V? I suppose you could add a 4K termination resistor if that will make a difference.I can name that circuit in 1 chip and 2 caps. For lower input offset voltage errors, choose a better chip.
ak
There still is a lot of ambiguity in the requirements. Is the 2.5 mA a minimum required output current, a max capable output current, or just the current required by the sensor? Don't know, but the circuit can be adapted.Since your input does not provide a sink for the 2.5 mA of current, will the input still be +10V? I suppose you could add a 4K termination resistor if that will make a difference.
Right. Since the poor fellow who made the original post is between a rock and a hard place; it seems only reasonable to toss out straws even if the relevance might be limited.There still is a lot of ambiguity in the requirements. Is the 2.5 mA a minimum required output current, a max capable output current, or just the current required by the sensor? Don't know, but the circuit can be adapted.
ak
by Duane Benson
by Jake Hertz
by Aaron Carman
by Duane Benson
