using a 5V/1A recom over a 780X for simplicity and efficiency. have used this circuit in the past with good results for alternative uses but thought it would work well for this project with the recom:
i understand the V listed on the circuit is a bit off, but that is just for reference at this point. also will probably change the 1n4004 to a 1n4148, other than that, please lmk your thoughts taking into the following conditions:
i have noticed that the recom datasheets do not recommend any caps at all but i am assuming they are expecting a relatively stable V, my input power will be bouncing all over the place between 9.5V-12.6V constantly and don't know how that will effect the recom vs a regular 780X and if caps should be around the recom due to that fluctuating incoming V.
this will be going on a radio controlled multirotor distribution board that powers an arduino, rx for the radio gear, video tx (1.2 (not yet, in the future) and/or 5.8GHz, 20mW for now, up to 500mW later) and 5V camera. on a side question, should i put some caps before the pins for the vtx/camera also or since the V @ 5V will be regulated, is it a non issue? either way, it is not an issue so please let me know the best way with what i have described. i would like to keep everything running off the main lipo and not run multiple batts, that is very important.
i will tap off this 5V output and use a 3V3 (ti tps71733) ldo reg to power the sensor board which consists of a 3axis gyro, 3axis accel (and possibly 3axis mag and barometer in the future).
here is the ds for the recom, going with the 5V unit:
http://www.recom-international.com/pdf/Innoline/R-78xx-1.0.pdf
thanks in advance for your time and advice,
bob
bob
