Recifier and output resistor
Discussion in 'General Electronics Chat' started by kvsingh21, Sep 15, 2008.
  1. kvsingh21
    Thread Starter Active Member
    Apr 15, 2008
    63
    Hi folks,
    I have a very quick question.
    Basically i have an amplifier with output resistor and a rectifier so that i can feed the output to LCD voltmeter. Now do i need a output resistor from only positive output from rectifier or negative output as well?
    The image has the rctifier missing, but it is inserted after C2.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If your voltmeter can do AC then it can simply be placed across the load resistor. The one load resistor is enough.
    Otherwise, place the diode's anode between the capacitor and the load resistor, and add a capacitor to ground tied to the cathode. That will give you a positive voltage on the capacitor. The capacitor will smooth out the DC so the voltmeter gives a steady reading.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    You also need a resistor from anode to ground.
