I have a number of devices in which I want to incorporate a connector with 3 input pins, 1,2,3. and 2 output pins a,b
When the charger is not plugged into the port, 1 & 2 are output on a,b , and these would be connected to the battery. So the device would run on battery power taken from a,b.
When the external charger is connected, 2,3 are active. since only 1,2 are connected to output a,b - the device now does not get any power.
3 is tied to the battery, so now the charger would just charge the battery and the device would be off.
I read about it here - but language turned out to be a big barrier..
http://www.dealextreme.com/forums/Forums.dx/Forum.0~threadid.352315
Any ideas what could work ? Essentially this connector has a mechanical switch that changes contacts if the charger is plugged in..
