Rech. Battery powered USB hub
Discussion in 'General Electronics Chat' started by james211, Oct 3, 2013.
  1. james211
    May 29, 2012
    210
    So I'm trying to figure out a solution for a product that doesn't exist, a portable, battery powered usb hub.
    So here's my thought....How hard could it possibly be to connect a rechargeable battery pack that would power a USB hub? Most seem to run on 5V's from what I've read.
    Typically I need to power portable hard drives via USB 3, which the ones I have currently draw about 225mA. But how do I figure out how many mAh it draws? I'd like to find a large enough battery to supply power for 4-6 hours.
    I know I'd need to reduce the power from a higher voltage down to 5V's, but I don't see that as being too hard.
    Think this could work?
  2. wayneh
    Sep 9, 2010
    12,361
    3,220
    It could work. You'll need a DC-DC converter to take the battery voltage to a steady 5V. The battery pack will have a mAh rating.
    One problem you'll have is that some USB devices are "smart", and adjust their behavior depending on a handshake with the host. They may not charge or run properly without a successful handshake.
  3. james211
    May 29, 2012
    210
    How would the device know its not using the DC power supply (wall wort) that was intended for the hub?
  4. wayneh
    Sep 9, 2010
    12,361
    3,220
    Ah, I see your point. I thought you were making your own hub. The hub itself should handle power allocation so you can ignore the handshake issue.
  5. james211
    May 29, 2012
    210
    Any idea on how I can figure out how many mA per hour the portable hard drive draws? I know the hard drive is drawing 225mA from the computer.
    The hub I'm looking at comes with a 5V / 4-Amp power supply. So where does Amps come into play with batteries?
  6. ronv
    Nov 12, 2008
    3,391
    1,444
    The drive will take 225 ma/hrs. So to run it for 6 hours you need batteries with 1350 ma/hr rating. 6 AA batteries would give you ~ 2000ma/hrs at 6volts when they were dead, so that might not be a bad choice. If you want to run several drives you can use bigger batteries. You could buy something like this to step the voltage down to 5 volts. It is pretty efficient so would only loose a little time.
    http://www.ebay.com/itm/1PCS-Lithiu...853?pt=LH_DefaultDomain_0&hash=item565bdb5b3d
  7. james211
    May 29, 2012
    210
    Awesome, just bought two! Now, I have a fair amount of Canon BP-911 batteries available to me, but I have no clue where to find a sled that I could put a barrel plug on. Any ideas? That would be ideal since I already have batteries and charger.
  8. ronv
    Nov 12, 2008
    3,391
    1,444
  9. ronv
    Nov 12, 2008
    3,391
    1,444
  10. Jibby
    Sep 12, 2013
    15
    225mA = 0.225A
    0.225 x6 x 4 =5.4 AH Battery of 5 Volts. As such a battery is not available take a 6V battery of near that AH.
  11. james211
    May 29, 2012
    210
    whats the difference between the product above and a standard dc-dc buck converter? I have LI step down above and it seems to be shorting out my batteries. I've double checked all my connection with a meter and can't find any shorts. I'm a bit confused...
