Receiver or transceiver
Discussion in 'The Projects Forum' started by gilblais, Nov 16, 2015.
  1. gilblais
    Sep 24, 2012
    9
    Need to signal a 'device' (that will be attached to an inventory unit) within a 300 +- square foot dimly lit area that will light up brightly or sound loud enough for the inventory unit to be located. WI-FI signal to be sent from server located anywhere within the area.
    Some of the inventory units have 12V DC batteries available as a power source and I would like to prototype the system with these units as a proof-of -concept. Other units will require some form of battery power. Each device will need a unique identifier and can number over a thousand. Need least expensive and dependable configuration since there are multiple geographic locations.
    The scene is that a picker will select a list of items using a intranet based tablet (or ??), which will sequentially signal where to find each item (signal will be sent from local server at each geographic location)
    I have the WEB based software completed to the level that the picker can generate the needed inventory list and I can do the remaining software once the 'device' and communication methodology are known and working.
    I need help with the communications infrastructure and programming to send a signal as previously described and the associated required electronics.
    I hope that I am not dreaming here. Thank you in advance for any help.
    Regards, Gil Blais
  2. GopherT
    Nov 23, 2012
    6,309
    4,029
    You need to describe what an inventory unit is (a fork truck, a robot, an RFID tag, ???).
    Also, are you sure of your dimensions? 300 sq. ft. is only 17'4" x 17'4". I can find that with only a few scans - unless it is yesterday's sox or underwear on my bedroom floor.
  3. mcgyvr
    Oct 15, 2009
    4,789
    975
    Whats wrong with proper shelf/aisle/bin labeling and a pick list (either paper or tablet based)?
    A simple barcode label at each bin and a wrist worn scan/verify system is far more cost effective (and just as error-proof as any visual bin scheme)
    Your dreaming if you expect this on a silver platter..
    You want us to develop a multi-location wireless visual poka yoke inventory picking system for you?
    I'd charge thousands of dollars for that..
    Do you know any programming?
    Hardware design?
    Database?
    What is your background/skill set?
    and yes.. 300 sq ft... please... thats got to be wrong
    ErnieM likes this.
  4. gilblais
    Sep 24, 2012
    9
  5. gilblais
    Sep 24, 2012
    9
    Ooops, I wasn't clear on the dimensions. It is 300 feet square i.e. about a square football field
  6. gilblais
    Sep 24, 2012
    9
  7. gilblais
    Sep 24, 2012
    9
    Yes, I have significant software skills (C/C++, Java, Javascript, PHP 7, HTML5, CSS3, IBM Assembler and a few more older ones, since I am quite old). I have extensive MySQL experience also. I put the first database on the Trident submarine for the US Navy.
    I am not trying to take advantage of anyone here - just a guy who came to this forum looking for help from folks who have the skillsets that I am totally lacking. If I have come to the wrong place, let me know please.
    You are right, the dimensions are incorrect. They should read that it is a football field square - 300 feet x 300 feet.
  8. gilblais
    Sep 24, 2012
    9
    Answering these statements: "Whats wrong with proper shelf/aisle/bin labeling and a pick list (either paper or tablet based)?
    A simple barcode label at each bin and a wrist worn scan/verify system is far more cost effective (and just as error-proof as any visual bin scheme)"
    Think of used items on wheels like a motorcycle/lawn mower/etc that will be moved each time a customer wants to see/start it up,etc in a warehouse a football field square. Allocating designated space for them doesn't work since the volumes vary too greatly so they are placed at the first open spot - that will not change.
    The goal is not to scan them when found, the goal is to find them in a sea of items.
  9. alfacliff
    Dec 13, 2013
    2,449
    428
    there are rfid devices available that do that.
  10. mcgyvr
    Oct 15, 2009
    4,789
    975
    Off the shelf systems already exist.. and the cost/number of "tags" needed will dictate if you should move forward on your own or just buy something already out there..
    RFID is probably the solution to go after.
    possibly BLE if you can attach multiple "locator" devices to get around the distance limitation..
    cheap wifi microcontrollers are out there now too.. something like the ESP8266 module can be had for $2 or less and depending on the number of tags you need it "might" be worth it to develop your own solution..
    A database to capture the MAC address or IP address and tie that to the product.. Then a lookup/alert function.
  11. ErnieM
    Apr 24, 2011
    7,436
    1,626
    A football field is only 300 square feet?
    Gee, on TV it looks much wider than one foot.
