receiver and transmitter that detect threads
Discussion in 'General Electronics Chat' started by golo, Jun 8, 2011.
  1. golo
    Jul 28, 2010
    I want to do a project that will detect the threads in the wire
    The wire has one input one output and some threads
    I want to put in the input 8 number a-synchronic serial code (I know what I put in the input) and in the output I want to decode this code and I know what I receive.
    With this two data that I know (input code and output code) I want to design an algorithm that will detect the threads in the wire
  2. Kermit2
    Feb 5, 2010
    3,837
    961
    The term 'threads' is confusing for most readers. Are these electricity conductors, or the kind of stuff pants and shirts are made from?
    A picture would be very helpful.
  3. mcgyvr
    Oct 15, 2009
    4,783
    973
    or does threads=packets ?
    Sounds to me like you want to create your own transmission protocol/handshaking...
  4. golo
    Jul 28, 2010
    I am sorry for the confusion​
    I mean that treads are electricity conductors
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You must have some hardware involved with this. Can you post a schematic?
  6. golo
    Jul 28, 2010
    Thanks beenthere,
    I know that I need to involved hardware, I don't have a schema because I don't design it, I will glad if you can help me to know what electronics components I can use in the electronic circuit
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It would seem to me that by simply reading the manufacturer's code and such information on the cable jacket would give you what you need. I can't really imagine how to make a checker - unless you will always be using 8 conductor cable and you need to tell if each conductor is shorted/open?
  8. tom66
    May 9, 2009
    2,613
    214
    Do you want someone to do your electronics homework for you...?
    I can think of one way to do this, albeit, very long winded: You could have a microcontroller with a stored table of numbers. The micro knows the length of the wire, that is input to it, and it also knows the gauge of wire (SWG/AWG/whatever.) It knows the inductance of a single, thick piece of wire. It could then measure the parallel inductances of several strands of the wire, which would be lower than one thick strand. With a great inaccuracy, it may be able to tell you the number of threads to within ±50%. :eek:
