Receive signal strenght indicator (RSSI)
Discussion in 'General Electronics Chat' started by Imphy, May 21, 2009.
  1. Imphy
    Feb 15, 2008
    Hi all,
    Does anyone already have tested the real sensitivity of a receiver using only the RSSI output pin of a receiver? If yes, did you get good results or did you get inconsistency results depending of each IC you were using. I know that to measure the real sensitivity of a receiver I should use a BER (bit error rate) but I am trying to test with out one.
    Thank you.
