Realtime location of a person in a room
Discussion in 'The Projects Forum' started by Adamf001, Oct 19, 2012.
  1. Adamf001
    Sep 5, 2011
    67
    I've had this idea for a while now and want to finally get it started, well at least an idea to progress forward.
    I would like to set up a method of accurately pin pointing the location of a person/ people in a room.
    I thought about using infra-red array in a grid system so that when you break a x axis light beam and a y axis beam the computer knows were you are... only problem is furniture and moving objects could disrupt the array...
    I also thought about using a transmitter/ receiver on the person in question, so when the transmitter sends a signal you calculate the time it takes to hit a sensor placed specificity in the room and thus determining the location..
    Any other ideas or suggestions????
    This idea will then allow me to develop like speaker and lights that can follow you around the room to give you maximum sound, light and cooling.
    again this is just an idea but what do you guys think? :D
  2. wayneh
    Sep 9, 2010
    12,388
    3,245
    How about pressure pads on the floor? Or maybe hack one of those Wii or X-box controllers that "watch" you
    Adamf001 likes this.
  3. Adamf001
    Sep 5, 2011
    67
    I like the wii remote idea, if you had like 3 all 'watching' the same person you could map their movements around the room... Thanks I'm going to defiantly look into that
