Really basic question about ac circuits
Discussion in 'Homework Help' started by wannabedoc123, Dec 4, 2010.
  1. wannabedoc123
    Dec 4, 2010
    Hey this is pretty simple but I'm just not getting it. I'm sorry if I sound really dumb, but I have the following questions:
    1. What exactly is power factor? If the question says the power dissipated is 25% of the power supplied, what do we take the power factor to be? 0.25? And if it says that the power consumed is 25% then?
    2. if a bar magnet falls freely vertically and passes through a copper ring in its path; but the ring is cut (ie it has a gap), then will emf be induced in the coil?
    I'd really appreciate any help anyone could give me!
  2. jimmychacha
    Dec 1, 2010
    10
    Doc, I can help you with number two, as I am currently studying this subject in Physics. An EMF, or voltage potential will be induced at the two ends of the copper ring. This emf will probably be very small since the "ring" you describe sounds like one coil, or turn of copper. If the ring were made of multiple turns, the emf would be greater. Also, the emf will last only a short period of time, the time that the magnet is in motion through the ring. When the magnet stops, the emf is gone. The faster the magnet moves through the ring, the greater the emf induced. When the magnet is withdrawn from the ring, an emf of opposite polarity is induced.
    Hope this helps,
    Jim
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
  4. mik3
    Feb 4, 2008
    4,846
    63
    I think you have confused power factor with efficiency.
    Can you show us where did you find these questions?
  5. blah2222
    May 3, 2010
    565
    33
    Like what was said before, you have mixed up efficiency with power factor.
    Power Efficiency = Pin/Pout
    Power Factor = Pout/|S|out
    Where |S|out is the apparent power dissipated from the load.
    Hope that helped.
  6. wannabedoc123
    Dec 4, 2010
    Thank you so much, everybody!
