Realizing subtractor difference using MUXs
Discussion in 'Homework Help' started by Mahesh Abnave, Oct 16, 2016.
  1. Mahesh Abnave
    Jan 12, 2016
    Which of the following combinational circuit gives the Boolean expression for DIFFERENCE of a full subtractor?
  2. crutschow
    Mar 14, 2008
    13,482
    3,370
    I give up. :confused:
    Which is it?
    Is this homework?
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Not only do you want someone to answer your homework question for you, but you don't even want to be bothered with indicating what the various signals -- {x, y, z} -- represent?
    How about starting with the Truth Table for a full subtractor? Or are we supposed to provide that, too?
  4. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    The answer is simple. The answer is: it is either A, B, C, or D.
    Once we get more info we might be able to narrow it down :)
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    It would also help if you indicated which input to the MUX corresponds to which state of the select signal.
    We are NOT mind readers!
