Realisation of Boolean expression
xxxyyy
Joined Oct 7, 2011
34
I have this expression: ACD+ABC+BD+ACD, where underlined letters are complements.
How can I realise this function using only:
a)NAND gate
b)NOR gate
I suppose that I should transform function above to get 2 new functions,one for realisation using only NAND gates, and second for realisation using only NOR gates.How can I do it?
panic mode
Joined Oct 10, 2011
2,759
I will use exclamation in front of signal to indicate that signal is inverted.
a)
NAND1 = inputs A, C, !D
NAND2 = inputs A, B, !C
NAND3 = inputs B, !D
NAND4 = A, !C, D
NAND5 = inputs are outputs from previous gates.
normally it is assumed that signals are available in direct and inverted form. if you need to create inverted signals for C and D, you can use additional pair of NANDs as inverters (just connect inputs of the NAND gate together).
b)
just use DeMorgan
NOR1 = inputs !A, !C, D
NOR2 = inputs !A, !B, C
etc.
NOR5 = inputs are from previous NOR gates.
just like with NAND, you can use NOR to make invertor by connecting inputs of the NOR gate together.
