Real-time problems which can use electronic circuits as a solution?
Discussion in 'The Projects Forum' started by xeroshady, Aug 23, 2012.
  1. xeroshady
    Aug 1, 2012
    11
    Hey everyone, can you suggest some real life problems that you face, which you may be able to fix with the help of some simple gadget or electronic circuit? It's for a college project.
    For example, when water stagnates at a place, instead of using buckets to transfer the water, you can use a portable motor or something, which can be operated by rotating a handle to generate power, hence not requiring a power source.
    I really can't think of any everyday problem that I face, which can actually be solved with electronic circuits.
    And since I'm a first year college student, I don't know much about circuit design, and won't be able to use components like ICs and OP-AMPS :/
    Suggestions anyone?
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    If you look through these Forums, you will find all sorts of real world problems that people want to solve.
    Google: FYP electronic
    (FYP=Final Year Project)
    Ken
  3. wayneh
    Sep 9, 2010
    12,368
    3,224
    Pet doors are a common one. Keep the raccoons out but let the pets in. Solutions can range from very low tech (I use a bucket in front of the door at night) to the latest RF and microprocessor tricks. Webcams, critter cams, internet connectivity, the works.
    I'd like to apply MPPT to an automatic transmission on a bicycle. Oops, did I say that out loud? Could be a patent opportunity. ;)
