I need a little help with understanding this problem and how it should be laid out (attached below).
In the question, it says the source impedance is 50 ohm and voltmeter impedance is 1M ohm.
Does this simply mean that I can model the system with a 50 ohm resistor in series after the source, and 1M ohm in series with the voltmeter?
And thus solve with Thevenin equivalence?
Thank you!
Thank you!
