Reading two pack smart battery data
Discussion in 'The Projects Forum' started by skybox, Jul 22, 2010.
  1. skybox
    Thread Starter Active Member
    Mar 2, 2009
    68
    Hi guys,
    I am using a two pack battery in my project. Each pack has its own SMBus communication wires using the Smart Battery protocol. I can communicate with each pack perfectly fine. I want to run the two battery packs in parallel.
    My question is:
    I tried to short Pack A Data line and Pack B Data line, Pack A Clock line and Pack B clock line for the SMBus protocol, and I can't get valid battery pack data. Is this even possible?
  2. windoze killa
    Feb 23, 2006
    605
    24
    Simple answer is no.
    You will need to employ a bit of logic and check each one individually.
  3. Bosparra
    Member
    Feb 17, 2010
    79
    Just out of interest, how are you reading the data?
  4. skybox
    Mar 2, 2009
    68
    Thanks. I will go ahead and try this. I believe they might have different addresses for each pack. Thanks !
  5. skybox
    Mar 2, 2009
    68
    Using a PIC microprocessor to read data off the battery
