Reading temperature from MCP9801 via I2C with 8051
Discussion in 'Embedded Systems and Microcontrollers' started by Cable Guy, Mar 31, 2012.
  1. Cable Guy
    Mar 23, 2012
    I am trying to communicate to a MCP9801 temperature sensor via I2C using a 8051 microcontroller.
    I wrote a routine to set the resolution in the config register to 0.0625 C and then read a byte from the temperature register in an array:
    Code ( (Unknown Language)):
    1.
    2. #include <I2C.h>
    3.
    4. void main()
    5. {
    6.         unsigned int i;
    7.     unsigned char a[8];
    8.
    9.     while(1)
    10.     {
    11.
    12.                 I2CInit();
    13.         I2CStart();
    14.
    15.         I2CSend(0x90); //device adress: 1001 00 [COLOR="#0000FF"]0[/COLOR] - [COLOR="#0000FF"]write operation[/COLOR]
    16.         I2CAck();
    17.
    18.         I2CSend(0x01); //pointer for selecting config register
    19.         I2CAck();
    20.
    21.         I2CSend(0x60); //value to write in config register
    22.         I2CAck();
    23.
    24.         I2CStop();
    25.
    26.         I2CStart();
    27.         I2CSend(0x90); [COLOR="#FF0000"]// dummy write command - for selecting the temperature register[/COLOR]
    28.         I2CAck();
    29.
    30.         I2CSend(0x02); //pointer for selecting the temperature register
    31.         I2CAck();
    32.
    33.         I2CSend(0x91); //read command
    34.         I2CAck();
    35.
    36.                 for(i=0;i<8;i++) //reading 8 bits from the hysteresis register into unsigned char array
    37.         {
    38.             a[i]=I2CRead();
    39.             if(i==7)
    40.                 I2CNak();
    41.             else I2CAck();
    42.         }// for
    43.
    44.         I2CStop();
    45.
    46.     }//while(1)
    47. }//main
    48.
    49. [/i]
    When I look in the I2C debugger terminal in Proteus VSM simulator, this is what I see:
    http://imageshack.us/photo/my-images/814/simulation.jpg
    I don't see the value in the temperature register (0x1B) anywhere.
    And the coresponding error message is : [MCP980X] Pointer Invalid -> most probably it refers to the temperature register pointer, but what is going on there is a dummy write - here is the extract from the MCP9801 datasheet showing how to read from the temperature register:
    http://imageshack.us/photo/my-images/51/readingdiagram.jpg
    And here is the content of the I2C header I am using (program written in Keil):
    1.
    2. #include <reg51.h>
    3.
    4. sbit SDA=P0^0;
    5. sbit SCL=P0^1;
    6.
    7. void I2CInit()
    8. {
    9.     SDA=1;
    10.     SCL=1;
    11. }//I2CInit
    12.
    13. void I2CStart()
    14. {
    15.     SCL = 1;
    16.     SDA = 0;
    17.     SCL = 0;
    18. }//I2CStart
    19.
    20. void I2CRestart()
    21. {
    22.     SCL = 0;
    23.     SDA = 1;
    24.     SCL = 1;
    25.     SDA = 0;
    26. }//I2CRestart
    27.
    28. void I2CStop()
    29. {
    30.     SCL = 0;
    31.     SDA = 0;
    32.     SCL = 1;
    33.     SDA = 1;
    34. }//I2CStop
    35.
    36. void I2CAck()
    37. {
    38.     SDA = 0;
    39.     SCL = 1;
    40.     SCL = 0;
    41.     SDA = 1;
    42. }//I2CAck
    43.
    44. void I2CNak()
    45. {
    46.     SDA = 1;
    47.     SCL = 1;
    48.     SCL = 0;
    49. }//I2CNak
    50.
    51. void I2CSend(unsigned char Data)
    52. {
    53.     unsigned char i;
    54.
    55.     for(i=0;i<8;i++)
    56.     {
    57.         SCL = 0;
    58.
    59.         if((Data&0x80)==0)
    60.             SDA=0;
    61.         else SDA = 1;
    62.
    63.         SCL=1;
    64.         Data<<=1;
    65.     }//for
    66.
    67.     SCL = 0;
    68.     SDA = 1;
    69. }//I2CSend
    70.
    71. unsigned char I2CRead()
    72. {
    73.     unsigned char i, Data=0;
    74.
    75.     for(i=0;i<8;i++)
    76.     {
    77.         SCL=0;
    78.         SCL=1;
    79.
    80.         if(SDA)
    81.             Data|=1;
    82.         Data<<=1;
    83.     }//for
    84.
    85.     SCL = 0;
    86.     SDA = 1;
    87.
    88.     return Data;
    89. }//I2CRead
    90.
    91.
    Also here is the MCP9801 datasheet for reference: http://www.datasheetcatalog.org/datasheet2/d/0jah5j3yagu1fft7wczs570sskfy.pdf
    What is it I am missing?
    Thank you for having the patience to go trough such a long post.
  2. Cable Guy
    Mar 23, 2012
    I have figure out my problem; anyone is free to laugh at my code, since I can't seem to be able to edit the previous message.:)
    I will be posting my complete thermostat project (C code and simulation screenshot) when it will be complete.
