Reading information from video glasses
Discussion in 'The Projects Forum' started by dta333, Mar 28, 2011.
Thread Status:
Not open for further replies.
  1. dta333
    Mar 6, 2011
    13
    My friend just came up to me with a pair of video glasses he has, and he cant find the recorder that came with it. He wants me to see if I can some how make something that could possibly read the information. I have access to an Arduino Duemilanove and a new beagleboard xM. I havent worked with any video peripherals before so I'm not sure where to start and would like to have some input on if I can do it. Here is a picture of the camera and the input it has. He said it records audio and video.
    Thanks for the help.
  2. bribri
    Member
    Feb 20, 2011
    133
    5
    do the glasses contain batteries?
  3. dta333
    Mar 6, 2011
    13
    No they did not. He said the recorder that it came with had an lcd screen and when attached the video feed would play on the screen and it had a record button. So it seems like the power came form the actual recording unit.
  4. bribri
    Member
    Feb 20, 2011
    133
    5
    well that's 3.5mm 4 pole jack... maybe 2.5mm?
    not working with a 'headphone' connector obviously.
    so i guess that's one contact each for:
    common, video, audio, and power.
    (with certain assumptions in mind)
    the main question of course would be, which is what?
    you might find a "pin-out" diagram for the make and/or model number.
    if the case is easy to open, a DMM could give you a very good clue also.
    the other question is, how many volts does it want?
    3.3? 5? etc.
    the next issue has to do with video format. having already assumed that the output is analogue... what is it?
    NTSC, PAL, SECAM, or one of the variants?
    with one of these standards it would be simple enough to find a compatible recorder, or for even less cash, some kind of video->USB digitizer thing... something which delivers a digital format which you can actually use of course.
    i suppose it could be some non-standard analogue format of video... then i guess you'd need to use a scope to figure out what it actually is..
    now i can't say that i've ever seen digital connectors of that 4 pole jack style before... i'd really doubt that it's some kind of usb, but then, who knows? if that's the case then i'd just wish you luck.
    whatever the case, would be good to get as much info about the specific product as you can find.
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    They look like 3D shutter glasses.
  6. bribri
    Member
    Feb 20, 2011
    133
    5
    they do.
    well, without the shutters ;)
    i don't think that would even be possible with curved glass come to think of it.
  7. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Maybe they're audio (no optics) with a mic.
    edit, ahh wee camera in the frame. No idea on what it needs though.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't see why they can't be shuttered. LCD is very flexable.
  9. dta333
    Mar 6, 2011
    13
    ok so assuming that these glasses are analogue and I figure out the pin-outs.
    this digitizer you are talking about can this be possibly plugged into something like a beagleboard xm. Which then can decode the images and maybe out put to a smaller screen?
  10. bribri
    Member
    Feb 20, 2011
    133
    5
    oh i just never actually seen any.
    but if it's possible i'd expect it to be more expensive than the generic 'flat panel' standard cheapo shutters which i've got.
    hmm. usb in, s-video out, on-board video decoding... i really don't see why not...
    but if you only want to go camera -> screen, you might save some time by leaving the digitizer and computer out of the loop.
  11. dta333
    Mar 6, 2011
    13
    Iv been busy with school so I had to take a break from the project but I was tinkering around and I think I found the pin outs for the glasses.
    pin 1 2 3 4
    1 = ground
    2 = video
    3 = audio
    4 = power
    power is 3.5v
    now that I know all the pins , how can find out what type of video the camera is outputting?
  12. monster_catfish
    Mar 17, 2011
    110
    107
    Hey I have a pair of video glasses, but they simply plug into the computer USB port to download the videos. Are you certain that your glasses do not have that basic facility ?
    My pair are Chinese-made, and I look like Buddy Holly when I put them on, but they do work as advertised, and then some, say no more.
  13. bribri
    Member
    Feb 20, 2011
    133
    5
    use a frequency counter,
    or just plug it into a t.v., or video projector, or whatever.
    most generally speaking:
    50Hz = PAL
    60Hz = NTSC
    what is your location?
    PAL equipment will tend to reproduce NTSC with no problems.
    (sometimes only in black & white)
    NTSC gear can't play back PAL signals.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    There is some ambiguity about these glasses. If they are shuttered they do not display video. This is by far the most likely scenario, especially out the USB port. Basically one side goes dark every other frame. This will allow a conventional monitor to display 3D.
    Video glasses exist, but they are a rare and expensive breed. I get the feeling from some posts people are assuming the latter. These glasses are way too small to do this function.
  15. dta333
    Mar 6, 2011
    13
    Monster Catfish:
    The only connection I have is the 3.5mm headphone jack so no usb for me. But do you know where you got those video glasses?
    bribri:
    I live in the United States so from what Iv looked up about PAL and NTSC, so im guessing most of my things are going to be NTSC.
    How easy is it to convert a ntsc signal or any analog signal to digital?
    Bill Marsden:
    yeah my friend said they were expensive and he bought them to record him doing his "extreme" sports through his perspective and it had a video recording thing it plugged into that broke when he fell on it
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    Perhaps, but those are not video. If they are he should be able to give us a make and brand. Again, they could be shutter, but they are way too small for true dual video. You need a substantial frame for video, as well as a feed from the video card, not the USB port. The substantial frame is need for all the wires connecting to it.
    You will not get video from the USB port.
  17. bribri
    Member
    Feb 20, 2011
    133
    5
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    Camera yes, video output, never. You stated it, back it up, show me. There is a reason you see video card build into motherboards, or pay you pay high $$ for cards.
    The glasses do have the connections to display video. LCD is simple, video display is not.
  19. bribri
    Member
    Feb 20, 2011
    133
    5
    you're contradicting the OP.
    your "video output, never" statement is false.
    aptina sells system on a chip CCD's (cmos) with analogue and digital video outputs for less the $30. that's PAL or NTSC output + raw digital formats. other companies sell similar things with mpg4 output.
    video output is common enough. eg:
    i don't understand what you are saying.
  20. dta333
    Mar 6, 2011
    13
    Ok so I'm home for break and I'm working more on the project I received the parts and made a splitter for the video glasses. One end feeds power to the glasses and the other end out puts the audio and video signal. When I plugged the glasses into the tv at school I got a message on the tv that said it did not recognize the signal. I plugged the glasses into a tv at home and this is the picture i get.
    Does anybody know what would cause this to happen? With the limited knowledge I have about video I'm assuming this is a PAL signal, but I dont know what to do to give me a clean picture.
Thread Status:
