A very good morning to you Strantor.You really put me into a fit with this one, Martinez. I'm not sure why; honestly the whole concept just seemed a little Rube Goldberg to me, but I suppose I've been itching for a reason to try some computer vision stuff and you gave me one. So for a few days I've been playing with this a little here, a little there.
Most of my programming of late has been Python; that's what's fresh in my head so that's what I wanted to use. I explored many avenues for image processing in Python (including opencv as Mr Chips linked); all of them turned me off in one way or another. Too complex, too much overkill, too little documentation, etc. So I went looking for the best language for simple image processing. I wanted something stupidly simple, as you alluded to maybe being a little programmatically averse, and whatever it would be, would be something I've never seen before. Seemed like anything that was good at image processing was hard to learn, and anything easy to learn had little or no native imaging capability. Then, in my quest for "simple image processing" I stumbled upon "Processing" - it's a java-based environment targeted at retards, noobs, and children (I meet all the criteria). I read about it in the past in "Making Things Talk" when playing with Arduino. I never downloaded it, but the book made it seem as if it were just some limited PC version of the arduino software. The IDEs look the same and in both the project is called a "sketch." Anyway, long story short, I was wrong. Processing is actually pretty badass. Stupid simple, good with images, plenty of examples come in the standard distribution. I never once had to google "how to _______ in Processing" - I was able to piecemeal my code together from the provided examples and fill in the gaps with intuition. It's less that 200MB fully extracted and requires no invasive installer. Very light on resources; I actually downloaded it to my little 7" winbook tablet and programmed everything you'll see here on that tablet (screenshots are from the tablet too, and I'm typing this on the tablet).
Here it is, without further ado...
code:
I realize that this method works artificially well, using static images. No matter how many times I copy and paste those dice, they do no change, and I will always get the right answer. Real dice are bound to be a little more tricky, but I think that if conditions are controlled, the effect will be negligible.Code:PImage img; // Declare variable "a" of type PImage int blackpxcount =0; int notblackpxcount =0; int hasran =0; int pixelsperdie = 187; int dots = 0; void setup() { img = loadImage("dice2.jpg"); // Load the image into the program size(img.width, img.height); // scale the window to match the image image(img, 0, 0);// Display the image at its actual size at point (0,0) } void draw() {// begin main script... if (hasran == 0){ //run only once, not continuously int begintime =millis(); // set the stopwatch, and we're off.. for (int y = 0; y < img.height-1; y++) { //for each row of pixels... for (int x = 0; x < img.width-1; x++){ //...and for each pixel in that row... color c = img.get(x, y);// read the color of the pixel, and... if (c < -10000000) {// if that pixel color is below a threshold, ... blackpxcount +=1;// we consider it black, and count it. }else{ notblackpxcount +=1; } } } //determine how many dots there are, based on how many black pixels we counted: dots = blackpxcount/pixelsperdie; // wrap it up and report our findings... int runtime = millis()-begintime; println("DONE! execution time: ", runtime, "mS."); println("total pixels: ", (notblackpxcount+blackpxcount), ", black pixels: ", blackpxcount,", not black pixels: ", notblackpxcount); println("number of dots showing: ", dots); //TO DO: ADD SOME CODE HERE TO OVERLAY THE NUMBER OF DOTS ONTO THE DICE IMAGE IN LARGE FONT (INSTEAD OF JUST THE DEBUG WINDOW) hasran = 1; //set this high so that the script does not run again, until... } if (mousePressed) {// ...we click the mouse. blackpxcount = 0; notblackpxcount = 0; hasran =0; //TO DO: ADD SOME CODE HERE TO ADVANCE TO THE NEXT FILE IN THE FOLDER, IF IMAGES ARE TO BE TRANSFERRED //IN FROM ANOTHER SOURCE. -OR- ADD FUNTIONALITY FOR THE SCRIPT TO ACCESS THE TABLET'S ONBOARD CAM DIRECTLY //AND IMPORT A NEW IMAGE UPON CLICK/TAP } //TO DO: ADD A "LEARNING" FUNCTION TO CALIBRATE "pixelsperdie" PARAMETER IF (WHEN) DOT COUNT //BECOMES INCORRECT DUE TO DIFFERENT DICE OR DIFFERENT CAMERA POSITION OR OTHER FACTORS }
I picture a trash bin with a tablet fixed in the bottom and a frosted glass plate on top. Think of a clear glass with wet (or maybe oiled) white paper on it. it is translucent and the camera can't see anything past the surface. Only what is sitting directly on the glass(or on the paper on the glass), and the glass is always at the same focal point, and light conditions inside the bin (provided by the tablet) should remain constant. I am confident that using 145 lines of code with an overkill computer vision plugin will not give any better end result than using these 39 lines of Processing caode with trash bin setup and tuning the threshold for die-dot-pixel-color and number-of-pixels-per-die-dot to your specific camera and trash bin depth.
When I posted this problem, I knew it was going to give an earworm to some... although maybe the word brainworm would be a better term ...
Yes, there's a reason why at first I tried to avoid using image recognition for this little project. The main one not being the hardware that would be needed, but rather the complexity of the code... and after reading your example, I realize that maybe I've been over-afraid of this... or maybe not...
Your code seems to assume that the only thing present in the image is one dice... and a perfectly squared and aligned one, for that matter. What I want to do is read 5 dice of two different colors, and when you take into account that they would land rotated practically all of the time, and that there might be imperfections like scratches, or moisture, or dirt in the surface onto which they've landed... and that they could land on top of one another, or leaning against the sides of the box, or against each other... or maybe even perfectly flat on the surface but so close to each other that their faces could be touching.... well, then you realize that the problem is a little more complicated than it seems. Especially if the algorithm involved works by line-scanning the image, and then reconstructing each face of each dice... I can't think of any other way of approaching the logic...
I foresee that if all those factors were to be included into the code, it would grow in size, if not exponentially, at least geometrically.
But I'm not averse to programming (I don't remember saying or implying that, I actually love to code) and I'm not completely allergic to the idea of image recognition... I might be a little stubborn, but I'm never obstinate... I was just trying to see if I could find a method other than optical to solve the problem... but it seems that optical is the simplest way to solve it, at least when one considers that it has zero-invasiveness for the players and for the dice themselves. And maybe the only way of getting a good feel on how hard to solve, and how fast it will perform, is to do what you just did... that is by dipping my brains into the problem and write some code already...
Thanks for sharing that link on Processing... it's been an eye-opener.
