Reading Amps with 100 mV meter
Discussion in 'General Electronics Chat' started by Gregfox, Mar 19, 2013.
  1. Gregfox
    Jul 23, 2011
    14
    Hello all,
    Does anyone know how I can read up to 2 amps on a millivolt panel meter that has a DC limit of 0-100 mA? I'm connecting the panel meter across a 1 ohm resistor to read current up to 2 Amp.
    Thanks!
  2. MrChips
    Oct 2, 2009
    12,646
    3,458
    If the meter reads 100mV fullscale you need a 50mΩ shunt resistor.
    PackratKing likes this.
  3. crutschow
    Mar 14, 2008
    13,508
    3,385
    It's simple Ohm's Law. R = V/I thus R = 100mV / 2A = 50mΩ as MrChips stated.
    You can buy an accurate resistive shunt designed for that purpose or, if you don't need high accuracy, you can use a short piece of small gauge wire to generate that resistance. A wire gauge resistance table will allow you to determine the required length for a given wire gauge.
  4. PackratKing
    Jul 13, 2008
    850
    216
    Either I can't read, or it would take a truckload of fine wire to equal a 50 megohm resistor... :D D'oh !!! :p or is it Duh !!!
  5. jmoffat
    Member
    Jul 18, 2012
    42
    100 mv / 2 A = 50 milli ohms! Lower case m is for milli. 50 megohms certainly would be many pounds of fine wire.
