reading a log chart
Discussion in 'General Electronics Chat' started by jut, Jan 8, 2010.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    I would say Vds = 5V and Id = 3A.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I get 2 amps/4 volts.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    I would also say Vds = 5V and Id = 3A.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    I think it is 5 Volts and 3 Ampere;
    Greetings,
    Bertus
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If you remember that 10^0 = 1 and each line between is one more than the previous one, it should be clear.
    The sequence of lines starting @ 10^0 is:
    [1,2,3,4,5,6,7,8,9,10] where 10 corresponds to 10^1
  7. VoodooMojo
    Nov 28, 2009
    503
    53
    I get 3.5 volts and 2 amps
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You've mistaken the parameter Vgs=3.5 volts for the Drain Source Voltage. The point at the arrowhead is at Vds=5V and Id=3Amps.
    Where'd you guys learn to read graphs?
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Throw darts.
  10. VoodooMojo
    Nov 28, 2009
    503
    53
    I cannot argue with that logic!
  11. mrmount
    Dec 5, 2007
    59
    7
    Vdc=5V and Id=3A considering 10^0=1 and every sub-division after that is incremented by one.
  12. jut
    Aug 25, 2007
    224
    :confused:\Rightarrow:D
    Thanks all for the help.
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    That's how I read it. They left off the 9V graticule.
