Reading a float number out UART
Discussion in 'Embedded Systems and Microcontrollers' started by hazzman, Jan 28, 2008.
  1. hazzman
    Dec 17, 2007
    13
    hey people,
    Im really close to achieving my objective but I seem to get a type conversion error/problem.
    I'm basically sampling from an temperature sensor in an ADC on a 8051 MCU and every second firing a timer to take a sample and send out on UART (RS-232) in which i have connected a serial cable to my PC with hyperterminal running. I have the ADC result saved as a float, but the UART has a 1 byte tx/rx buffer so tried using sprintf:
    Code ( (Unknown Language)):
    1.
    2. char cArray[4];
    3.
    4. fADCresult = getADCresult();
    5. sprintf(cArray, "%3f", fADCresult);
    6.
    7. for (i=0  ; i<sizeof(cArray); i++)
    8.   {
    9.     UART0_WAIT_AND_SEND( cArray[i] );
    10.   }
    11.
    12. // in header file:
    13. #define UART0_WAIT_AND_SEND(x) \
    14. do                             \
    15. { while (!UTX0IF);             \
    16.   UTX0IF=0;                    \
    17.   U0DBUF=(x);                  \
    18. } while (0)
    19. [/i]
    Hyperterminal shows:
    Tâ"þTâ"þTâ"þTâ"þ // repetitively on and on....
    The above doesn't get me anything
    However if i just do like :
    1.
    2. /*sprintf(cArray, "%3f", fADCresult);  // Get rid of this sprintf*/
    3. UART0_WAIT_AND_SEND((unsigned char)fADCresult);
    4.
    Hyperterminal:
    TÁTÁTÁTÁTÁTðTðTðTðTðTðTðTðTðTƒTðTðTÁTÁ /* Ignore the 'T's i add them in as i need to send out a byte first. A changing output when i touch the MCU, built in temp-sensor*/
    So i know ADC readings are occuring by the output(random character/symbols) changing when i warm up the MCU (touch it with my finger! - v. technical!) and they change back when i let go.
    So my question is how can i get the ADCresult float value into a char array(string) to output onto hyperterminal as the char array equivalent of the fADCresult float vals ?????? I know i'm close!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Might you have a problem with the data typing? The output of an ADC is an integer, not floating point. If it's a bipolar conversion, it's a signed integer.
  3. hazzman
    Dec 17, 2007
    13
    ok to clarrify why i use float here is my temp sensor sampling code:
    1.
    2. // header file:
    3. #define SAMPLE_TEMP_SENSOR(v) \
    4. do {                          \
    5. ADCCON2 = 0x3E;               \
    6. ADCCON1 = 0x73;               \
    7. while(!(ADCCON1 & 0x80));     \
    8. v = ADCL;                     \
    9. v |= (((unsigned int)ADCH) << 8); \     // ADC result in two bytes, ADCH:ADCL
    10. } while(0)
    11.
    12. // in .c file:
    13. void getTemp(void)
    14. {
    15.   unsigned int adcValue;
    16.   float outputVoltage;
    17.
    18.   SAMPLE_TEMP_SENSOR(adcValue);
    19.   // Note that the conversion result always resides in MSB section of ADCH:ADCL
    20.   adcValue >>= 4; // Shift 4 due to 12 bits resolution
    21.
    22.   outputVoltage = adcValue * CONST;       /* calibration for ADC temp sensor*/
    23.   fADCresult = ((outputVoltage - OFFSET) / TEMP_COEFF);  /* put calibrated
    24.  result in a floating point variable: fADCresult */
    25.
    26.
