Which function is used to read or write data in EEPROM memory for pic16f877a?
I'm using C-compiler.Which compiler you are using??.. .In mikroc there are built in functions..
Try this link it might help you..
Using Internal EEPROM PIC Microcontroller
where is the link?Please read the datasheet!
Check the whole section 4 "Data EEPROM and Flash Program Memory". This is for PIC16F877 but it should be the same for PIC16F877a.where is the link?
There are many many C compilers for the PIC.I'm using C-compiler.
