Read latching solonoid valve position
Discussion in 'General Electronics Chat' started by fsoender, Aug 18, 2016.
  1. fsoender
    Dec 10, 2015
    26
    I got an latching solenoid that I wish I could read the 2 positions of the valve. I tried Hall sensor, but the housing is to thick to read anything.
    I was thinking, would reading the coil do the trick, when its latched, I could resonance it some how and see if its latched or not?
    Any suggestions?
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    That should work if the coil inductance varies according to the armature position.. Can you post a link to the solenoid datasheet?
    Is there space for a simple microswitch?
  3. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    What is the device that you are using to input the Read posn to?
    When it is latched or unlatched there is no power to it so it probably will come down to a physical position of the plunger if it is required to be read at any other time.
    Max.
  4. fsoender
    Dec 10, 2015
    26
  5. fsoender
    Dec 10, 2015
    26
    It will be on an microcontroller.
    Yes its just an pulse, but wont you be able to "test" the position after its changed position by measuring the resonance?
  6. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Small inline pressure switch on the output side?
    Max.
    fsoender likes this.
  7. fsoender
    Dec 10, 2015
    26
    I wish, no room
  8. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    You could record the last position via polarity on activation, but not after, are you anticipating it drop out of its own accord?
    Or is it last state in case of a power outage?
    Max.
  9. fsoender
    Dec 10, 2015
    26
    I do record it, but I want to have a better feedback due to vibration or shock that can potentially unlatch it.
    I want to keep recording the position...
  10. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    No way of cushioning it and if necessary and couple with flex pipe?
    Max.
  11. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    If you can remover the cover and see where the magnetic armature ends up, you could insert a Honeywell SS400 mini hall effect device which has a TO92 case so very small.
    They have Unipolar, bipolar and latched variety.
    Max.
