Reactance VS linear resistance
Discussion in 'General Electronics Chat' started by AcousticBruce, Mar 25, 2014.
  1. AcousticBruce
    Thread Starter Active Member
    Nov 17, 2008
    58
    In a AC circuit with a CONSTANT frequency, can you use a capacitor as resistance to save power loss?
    Is there a time you would not want to use a capacitor for that?
    When would you WANT to use a capacitor for for reactance resistance?
    My questions are based on a non-changing frequency in a circuit.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    It is common practice in high frequency circuits to use 2 capacitors as a voltage divider. It seems that resistors would work as well, but as you said, capacitors have no proportional heat generated.
  3. shteii01
    Feb 19, 2010
    3,519
    515
    Well, the "resistance" of the capacitor in AC circuit is well known. It even has a name: Impedance. Usually designated by: Zc. Units of Impedance: Ohm, same as any Resistor.
    So.
    Zc=1/(sC)=1/(jwC)=-j/(wC)=-j/(2*pi*f*C) Ohm
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Circuits use capacitors or inductors as ballast all the time, since they don't actually use any power. Fluorescent and LED circuits can both be prime examples.
    Since there is no power conversion into heat as with resistors efficiencies tend to go way up and stay there
    RunFromYourWife likes this.
  5. AcousticBruce
    Nov 17, 2008
    58
    That sounds really interesting. How high frequency? Like radio?
    I was looking at the impedance formula  Z = sqrt{R^2 + X_c} and calculating the Xc with  \frac{1}{2\pi \cdot f \cdot R}
    I noticed that you can use the  \frac{1}{2\pi \cdot f \cdot R} when there is no resister, but if there is a resistor, you must also use  Z = sqrt{R^2 + X_c}
  6. shteii01
    Feb 19, 2010
    3,519
    515
  7. #12
    Nov 30, 2010
    16,705
    7,358
    I learned about those in the old vacuum tube TV's.
    Maybe not relevant to todays TV's, but still a valid method to be considered if your design is leading you toward needing a high frequency voltage divider.
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    I used some surplus caps to slow some fans for video game cabinets, I dont remember the cap values, just paralelled some till the desired speed was achieved. this made them a lot more quiet. one thing to watch out for is getting the circuit near resonance, the voltage and current can go way up at that point.
  9. daviddeakin
    Aug 6, 2009
    207
    27
    Yes. The technique is sometimes called a "wattless dropper". Some circuits that are powered directly from the mains use a capacitor to drop the voltage in this way.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    Unfortunately, that subject is taboo on AAC. There will be no further discussion of this point or the moderators will shut it down, quickly.
