I believe this is what I need to replace S1 from the schematic to use 24V on the switch side and 110V for the winch side. Please let me know if you see any problem. Basically compare the functionality provided by the two drawings.
R!f@@, everything needed should be in this picture. The "NEW" drawing should do the function of "S1" but instead of the DPDT switch, use two push buttons at lower voltage on the switch side.
BillB3857 or anyone else - would you mind confirming these relays and transformer should work? I can get these today:
http://www.grainger.com/Grainger/OMRON-Square-Base-General-Purpose-Relay-2W929
http://www.grainger.com/Grainger/WHITERODGERS-Transformer-3A358
And hopefully one last question - are these relay sockets the best way to wire these up? Granger part #4DG59
http://www.grainger.com/Grainger/OMRON-Relay-Socket-For-Double-Pole-Double-4DG59
Thanks,
charles
Thanks,
charles
