hi all,
i tried doing the example program for bulk transfers in usb emulating rs232 for pic18f4550.
An array ,with values that resemble a sine wave, was already assigned in that example program. i got that working.
now i want to use the internal adc (an0, with sampling freq fosc/2) and store the sampled values instead of that array mentioned previously.
I initialized the adc setup in the main function and then called a function which is 'for 'looped to get 256 sample data and store it in an array....
#define SINE_TABLE_SIZE 256 ///global declarations
static int sine_table[SINE_TABLE_SIZE];
void arraysine(void){
int1 i;
int8 value;
for(i=0;i<256;i++){
set_adc_channel(0);
delay_us(10);
value = read_adc();
sine_table=value;
is this correct, or any other suggestions
reply
thank you.
int1 i;
int8 value;
for(i=0;i<256;i++){
set_adc_channel(0);
delay_us(10);
value = read_adc();
sine_table=value;
reply
thank you.
