Re: microprocessor qns
Discussion in 'Embedded Systems and Microcontrollers' started by andrewys, Oct 19, 2009.
  1. andrewys
    Oct 19, 2009
    Hi All,
    I have a micro-controller that i programmed few years back. However, i have lost the program code due to hdd crash. Is there a way to extract the program code from my micro-controller?
  2. t06afre
    May 11, 2009
    It depends;) most UC vendors offer protection options for code. If this option is set, you will not be able to read out the firmware. But else you should be able to download the firmware. For downloading the code you need a programmer device. Which UC do you have?
  3. Markd77
    Sep 7, 2009
    Assuming that you can download the code from the chip, it will not have variable names, comments, or labels for the gotos and calls. This would be fine for making other copies of the chip but it would probably be easier to recode it than try to figure out how to modify the code, unless the changes you need are trivial.
