RE:FM HETERODYNE TRANSMITTER
Discussion in 'General Electronics Chat' started by NKEONYINYE, Nov 29, 2008.
  1. NKEONYINYE
    Oct 25, 2008
    Hi Senior Member Bertus
    Please,I am was confused at some of the stages as follows:(1) The stage coupled directly to the VFO: Please is this an IF amplifier or a buffer? The limited literatures I have been able to contact show that a VFO's output is coupled to a buffer (unity gain but I calculated the gain of that transistor circuit and got 2.36.(2) Is the last circuit before the PA an RF amplifier? (3) I have not been able to find a 10.7MHz IF transformer but it seems to me that the IF transformer acts as a filter as well as a “coupler”. So can I replace it with a filter circuit and in what way (the circuit diagram)? What effect will it give to the transmitter? (4). I was not able to get a 44.9333MHz crystal but a 47.5MHz crystal. Can I use this and if yes, how can I finally achieve the same 145-146MHz transmission frequency.(5) Please what are the inductance values of the coils (L1-L3 and T3), or, with what wire gauge and core diameter were the turns achieved.
    Please the link to the FM heterodyne transmitter I am refering to are as follows: http://forum.allaboutcircuits.com/showthread.php?t=13137&highlight=heterodyne+transmitter
    http://web.telia.com/~u85920178/tx/fm-tx1.htm
    I sincerely appreciate you all.
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Here is the original schematic you are refering to :
    [​IMG][​IMG]
    In the origenal versrion L1 is tuned round 10.7 Mhz.
    This is mixed with 3 X 44.933 ( ca 135 Mhz ) , the result is 145.7 Mhz.
    In you case the mixing frequency will be 3 X 47.5 ( ca. 142.5 Mhz ).
    To get in the 144 - 146 range the oscillator must be 1.5 Mhz - 3.5 Mhz.
    So you will have to change the circuit round L1 and T1 to get it working.
    Greetings,
    Bertus
  3. NKEONYINYE
    Oct 25, 2008
    Thank you so much for the answer
    Regards
    NKEONYINYE
  4. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    I have recieved a PM that you can not find some parts.
    I think all the parts can be ordered at BOX73 ( www.box73.de ).
    They also have the original crystal used in the transmitter.
    I have attached a PDF with the RF parts page from the magazine FUNKAMATEUR ( www.funkamateur.de ).
    Greetings,
    Bretus
