Re: digital elevator
Discussion in 'Homework Help' started by kautilya, Feb 8, 2009.
  1. kautilya
    Thread Starter Active Member
    Apr 26, 2007
    39
    Hi there. I am working on a digital elevator using a microcontroller 89C51. ht elift starts from the ground floor. the lift is supposed to travel upto 'n' floors. Also while travelling it should respond when all buttons are pressed simulatneously. when all buttons are pushed it should go floor-wise and stop on the desired floors. also priority should be given to up/down direction. if the lift is trvelling up then it should continue to travel up regardless of whether the down button is pressed or not and vice versa. the output of the push button should be displayed on a 3-1/2 segment LCD display.
    can u help me out with the block diagram algorithm for the same?
    regards
    Ashwath
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
