If you don't mind maybe you could post a fresh copy of your source code. It has been a while since this post was started and like the hardware the software has changed a bit at least since the start.
I still think you need to abandon the interrupt service routine in favor of a normal subroutine call. At the moment it is an added complication and doesn't bring anything to the party.
The last thing you need right now is to have to master the concept of interrupts. There will be time for that exercise later once things are up and running normally.
hgmjr
hgmjr
