Re. A/D converter display on LCD
Discussion in 'Embedded Systems and Microcontrollers' started by Ebuka, Dec 8, 2010.
Thread Status:
Not open for further replies.
  1. Ebuka
    Dec 8, 2010
    10
    Am having problems getting my A/D conv. value display on my LCD the cursor goes through the first line but nothing visible shown. Am using a 16X2 LCD.
    I have included the schematics Pls do have time look at my codes
    #include <REGX52.H>
    #include <Stdio.h>
    Thanks..
    #define LCD_data P2 // Data will be sent to/recieved from the LCD throught this port P2
    #define LCD_rs P1_0 // 0 = Instruction input 1 = Data input
    #define LCD_rw P1_1 //0 = Write to LCD module 1 = Read from LCD module
    #define LCD_en P1_2 // Enable Signal
    #define ADC_port P2 // A/D converter port
    #define rd P1_3
    #define wr P1_4
    #define cs P1_5
    #define intr P1_6
    #define OUTPUT P3 // A/D value moved here.
    // Function Declerations....
    void LCD_Power_on(void);
    void LCD_Busy(void);
    void LCD_Get_signal(unsigned char signal);
    void LCD_Send_signal(unsigned char signal);
    void LCD_Send_String(unsigned char *signal);
    void LCD_Initialize(void);
    void convert();
    void read();
    unsigned int ADC_value;
    // The main loop....
    void main (void)
    int i;
    unsigned int a,b,c,d,e,f,g,h;
    unsigned int convertr[9];
    LCD_Busy();
    convert();
    LCD_Busy();
    read();
    LCD_Power_on(); // 15ms delay
    OUTPUT = ADC_value;
    a = 1.5; b = 4.9; c = 9.2; d = 6.5; e = 4; f = 6.4; g = 8; h = 12;
    convertr[0] = ((OUTPUT + 1) * a) / 16 ; //round to 0
    convertr[1] = ((OUTPUT + 1) * b) / 16 ; //round to 1
    convertr[2] = ((OUTPUT + 1) * c) / 16 ; //round to 1
    convertr[3] = ((OUTPUT + 1) * d) / 16 ; //round to 1
    convertr[4] = ((OUTPUT + 1) * e) / 16 ; //round to 0
    convertr[5] = ((OUTPUT + 1) * f) / 16 ; //round to 1
    convertr[6] = ((OUTPUT + 1) * g) / 16 ; //round to 1
    convertr[7] = ((OUTPUT + 1) * h) / 16 ; //round to 1
    LCD_Initialize();
    for(i=0;i<9;i++)
    LCD_Busy();
    LCD_Get_signal(convertr);
    LCD_Busy();
    LCD_Send_signal(convertr);// Set CGRAM adress,data is Avaible from uC
    LCD_data = convertr;
    scanf("%s",LCD_data);
    /// End of main loop
    int a;
    for(a=0;a<25000;a++);
    void LCD_Busy(void)
    unsigned char i,j;
    for(i=0;i<100;i++)
    for(j=0;j<255;j++);
    /* to get your signal you have to enable the LCD pins to read and more*/
    LCD_data = signal; //Function set: 2 Line, 8-bit, 5x8 dots
    LCD_rs = 0; //Selected command register
    LCD_rw = 0; //We are writing in instruction register
    LCD_en = 1; //Enable H->L
    LCD_en = 0;
    LCD_Busy(); //Wait for LCD to process the command
    while(*signal) //till string ends
    LCD_Send_signal(*signal++); //send characters one by one
    LCD_rs = 1; //Selected command register
    LCD_en = 0;
    LCD_data = 0x38; //Function set: 2 Line, 8-bit, 5x8 dots
    LCD_rw = 0; //We are writing in data register
    LCD_en = 0;
    LCD_data = 0x0F; //Display on, Curson blinking command
    LCD_en = 0;
    LCD_data = 0x01; //Clear LCD
    LCD_en = 0;
    LCD_data = 0x06; //Entry mode, auto increment with no shift
    LCD_en = 0; //Enable H->L
    LCD_Busy();
    void convert()
    cs = 0;
    wr = 0;
    cs = 1;
    wr = 1;
    while( intr == 1);
    void read()
    cs = 0;
    rd = 0;
    ADC_value = ADC_port;
    cs = 1;
    rd = 1;
  2. spinnaker
    Oct 29, 2009
    5,065
    1,164
    You already have one thread started with this same subject. Why are you starting another?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Please confine this discussion to the thread already open.
Thread Status:
