Rds(on) graph in MOSFET data sheet
Discussion in 'General Electronics Chat' started by strantor, Sep 25, 2011.
  1. strantor
    Thread Starter AAC Fanatic!
    Oct 3, 2010
    4,302
    1,989
    I'm looking at the IRFP4110PbF datasheet and trying to figure out what my Rds(on) will be @ a junction temp of 120C. The "rated" typical value is 3.7mΩ and the "max" is 4.5mΩ, but when I look at the graph, 120C corresponds to about 1.75. That makes me think it is a multiplier, but if I multiply 3.7 * 1.75 I get 6.5mΩ. so what gives?
  2. Pencil
    Dec 8, 2009
    271
    38
    I am just guessing, but my observation is that
    the Rds On Typ and Max are given at Tj=25C,
    and the graph passes through 1 at what looks to
    be 25C. This supports your theory of the value
    being a multiplier. The Rds ON of a MOSFET
    increases with temperature, this is a characteristic
    of MOSFETS that makes them ideal for paralleling to
    share current, it helps to prevent thermal runaway
    and "current hogging".
    Just my observation.
    strantor likes this.
  3. vrainom
    Member
    Sep 8, 2011
    109
    19
    The typical and max value variation is from one device to another, measured at 25ºC. One device can have an Rds on of 3.7mΩ and the next one as high as 4.5mΩ at 25º but those values go up with temperature.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    Right, but go up to what; is what I'm trying to figure out.
    If 4.5 is worst case then I assume, according to the graph, that figure would be multiplied by 1.75 for a Rds(on) of 7.87mΩ. do you concur?
  5. vrainom
    Member
    Sep 8, 2011
    109
    19
  6. strantor
    Oct 3, 2010
    4,302
    1,989
