RCL-parallel, I know current's but how to calculate Z?
Jeo
Joined Nov 26, 2006
Hi!
I got RCL-parallel, I know current I (for Z), Ir, Ic and Il, so how can I calculate the Z from these informations? (I know voltage source value 10V , R 500 ohm ,L 2,5 mH and C 0,7 uF but it was mentioned that calculate Z with only using currents).
Jeo
Papabravo
Joined Feb 24, 2006
21,159
Ohm's law my friend
Rich (BB code):
if V = I * Z then
Z = V / I
That's not acting...It's ALGEBRA!
To compute the branch impedances you don't need the inductance or capacitance values.
To compute the reactances you also need to know the frequency.
Jeo
Joined Nov 26, 2006
I know that E=IZ but if I need to calculate Z only using branch currents (I know frequency)? Any ideas? There is something about "I is equal to Z and Ic equal to Xc".. Meaby I cheat and use ohm's law..
