RCA jack for copper clad?
Discussion in 'The Projects Forum' started by upand_at_them, May 31, 2015.
  1. upand_at_them
    Thread Starter Active Member
    May 15, 2010
    246
    29
  2. flat5
    Nov 13, 2008
    403
    17
    They are made to be soldered.
  3. Lestraveled
    May 19, 2014
    1,957
    1,218
    I see nothing wrong with these connectors. No grinding required.
  4. upand_at_them
    May 15, 2010
    246
    29
    My previous experience with things having that kind of plating were nearly impossible to solder. I ordered them, so I'll know in about three weeks. I might have to finally get one of those high wattage pistol grip irons.
  5. wayneh
    Sep 9, 2010
    12,396
    3,246
    That shouldn't be necessary - a "pencil" iron should be fine, although your copper-clad can be a challenge.
  6. flat5
    Nov 13, 2008
    403
    17
    You should have flux in your soldering kit. Perhaps more than one kind.
    More important in this case than a more powerful iron.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    coming here, always enjoying to encounter "another world", where reality is considerably different.
    Grinding off the plating from a RCA connector, for sure.
  8. wayneh
    Sep 9, 2010
    12,396
    3,246
    Why would you waste time grinding anything? Touch the iron to it, done.
  9. flat5
    Nov 13, 2008
    403
    17
    In a project I wanted to use the case of a pot for a ground meeting place. It was coated and I had to file it.
  10. takao21203
    Apr 28, 2012
    3,578
    463
    a 50W soldering station makes these tasks more easy. Soldering to the case is semi professional at best, for sure sometimes its handy + a problem solver.
    Just sizzle the thing for a while, however, the plastic in these RCA connectors melts fast so its not really good soldering to the encasing/the actual connector.
  11. upand_at_them
    May 15, 2010
    246
    29
    The jacks finally arrived. Soldering seems to be fine, with flux and letting the iron heat up the joint for a few seconds.
    atferrari likes this.
  12. flat5
    Nov 13, 2008
    403
    17
    Another case solvderd.
