RCA CA3100T obsolete 38mHz IC for NAD 3080
Discussion in 'General Electronics Chat' started by kim Hansen, Mar 28, 2015.
  1. kim Hansen
    Mar 20, 2015
    5
    Anyone who knows where to find this old Harris or RCA CA3100T 38mHz IC?
    I try to renovate two very well sounding NAD's. To a reasonable price , the NAD 3080 was one of the first amplifiers that was able to drive a load in 2 Ohm.
    The TO-3's in NAD 3080 : NEC 2SD287 /2SB539 delivers in the "A" version 10 A by max. 120 Vceo and 7/8 mHz .....10A is to the limit when the load is 2 Ohm.
    The mentioned TO-3 NEC's are obsolete as well.
    Any suggestions where to find TO-3 /TO-204 op transistors with 12A or 15A and the above mentioned specs ..120V / 7/8 mHz?
    _____________________________________________________________________
    https://sites.google.com/site/httpstubeamp/home/nad-3080
  2. Dodgydave
    Jun 22, 2012
    5,144
    769
  3. GopherT
    Nov 23, 2012
    6,304
    4,027
    The 2N6341 is a replacement for the big NPN if you have the b or c version - in stock at Newark.com
    Here is a cross reference list. Note there are a, b, c and un-lettered versions of your power transistors.
  4. kim Hansen
    Mar 20, 2015
    5
  5. kim Hansen
    Mar 20, 2015
    5
    Is it "Newark.com" in Chicago? As far as I can see the datasheets says that 2N6341 does not have a complementary PNP....?? Otherwise the 2N6341 would have been a super transistor for the 3080.
  6. kim Hansen
    Mar 20, 2015
    5
    Just bought 2 pcs. genuine RCA CA3100T's :) ....still missing substitutes for the TO-3 / TO-204AA NEC 2SD287 /2SB539..........?
