RC522 RFID Reader waiting for TAG, when I need Main Loop to run constantly
Discussion in 'Programmer's Corner' started by combover61, Jan 27, 2016.
  1. combover61
    Oct 16, 2015
    12
    Main Loop worked great.
    RFID read, write and display worked great.
    Combined the two, and the RFID is waiting for a TAG to be read ... preventing the Main Loop from running constantly.
    How can I have the RFID reader constantly available for new TAGs, yet keep my Main Loop running constantly?
    Code below, RFID library that is called is attached:
    Code (C):
    1.
    2. void loop() {
    3.
    4.     if ( ! mfrc522.PICC_IsNewCardPresent()) {           // Look for new RFID cards
    5.
    6.         return; }
    7.
    8.     if ( ! mfrc522.PICC_ReadCardSerial()) {             // Select one of the RFID cards
    9.
    10.         return; }
    11.
    12.     mfrc522.PICC_DumpToSerial(&(mfrc522.uid));          // Dump debug info about the card. PICC_HaltA() is automatically called.
    13.
    14.   if (mfrc522.uid.uidByte[0] == 0x61) {                 //
    15.
    16.     Serial.println(“blue”);
    17.
    18.   } else {
    19.
    20.     Serial.println(“card”);
    21.
    22.   }
    23.
    24.   Serial.println();                                     // Go to next line
    25.
    26.
    27.   // read the state of the vibration sensor latch
    28.
    29.   HITState = digitalRead(HITPin);     // vibration sensor latched ON by debounce circuitry?
    30.
    31.                                       // if it is, the HITState is HIGH
    32.
    33.   if (HITState == HIGH) {
    34.
    35.     digitalWrite(CLEARHITPin, HIGH);  // reset debounce circuitry
    36.
    37.     delay(500);                       // wait for 1/2 second
    38.
    39.     digitalWrite(CLEARHITPin, LOW);   // complete reset of debounce circuitry
    40.
    41.
    42.
    43.   LEDS = LEDS-1;           // set LEDS variable for number of LEDs to light
    44.
    45.
    46.
    47.   switch (LEDS) {
    48.
    49.     case 0:
    50.
    51.       analogWrite(BARGRAPHPin, 00);   // 0  LEDs ON
    52.
    53.       break;
    54.
    55.     case 1:
    56.
    57.       analogWrite(BARGRAPHPin, 13);   // 1  LED  ON
    58.
    59.       break;
    60.
    61.     }
    62.
    63.   } else {
    64.
    65.   }
    66.
    67.     delay(50);                       // wait for 0.05 second
    68.
    69. }
    Mod edit: Added code tags
  2. JWHassler
    Member
    Sep 25, 2013
    205
    34
    Name your platform and use code tags
  3. Picbuster
    Member
    Dec 2, 2013
    391
    53
    Read RFID under interrupt. the main loop will run until it 'sees' a rfid received flag.
    takes you 10 min to change your program.
  4. MrSoftware
    Oct 29, 2013
    546
    133
    Using interrupts is a great idea, and alternatively there might be a way to make a non-blocking read call to your device. Perhaps poll the device to see if data is waiting. You would have to see the docs for the device or its driver/library to determine this.
