RC Transfer function
Discussion in 'Homework Help' started by alexmath, Apr 4, 2015.
  1. alexmath
    May 2, 2014
    17
    Suppose R = C = 1 then the transfer function from the input voltage to the voltage across the capacitor is 1/ (s+1). So Vc(S) / V(S) = 1/(s+1). Getting back to time-domain: Vc(t) = V(t) * e^-t. What's wrong here? Thank you!
  2. shteii01
    Feb 19, 2010
    3,504
    512
    C is complex, R isn't.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Hello there,
    Constant voltage sources V(s) transform into V/s they do not stay the same when there is a step input. So V(s) => V/s so your Laplace is not V/(s+1) it is (V/s)/(s+1)=V/(s*(s+1)). If the voltage source is 1v then this is simply 1/(s^2+s).
    Find the inverse of that and you'll be very happy :)
  4. alexmath
    May 2, 2014
    17
    Thank you! I'm very happy right now! Have a good day.
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    The statement R=C=1 is nonsensical.
    That's like saying that the height of a car and the weight of a building are both equal to 1. Totally meaningless.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If C is capacitance measured in farads, then it is a real number. The reactance of C, Xc, with units of ohms is also a real number. The impedance or admitaance of a capacitor C is a complex number. In the ideal case it would have a zero real part. For a real component there will be some equivalent series resistance.
