RC Time
Discussion in 'General Electronics Chat' started by Lundwall_Paul, Apr 1, 2012.
  1. Lundwall_Paul
    Thread Starter Active Member
    Oct 18, 2011
    222
    19
    What are valid RC time constant are there general rules or capacitance to resistance ratios that are recommended?
    Like a 1 Farad capacitor (which if existed would be huge) and a three ohm resistor makes a real bad choice for a three second delay.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    You always try to keep the capacitor small and the resistance large because all (small) resistors are the same price but big capacitors cost big money.
    The other people may now point out the exceptions.
  3. Blofeld
    Feb 21, 2010
    82
    18
    I agree with #12.
    An upper limit for the value of the resistor is given by the fact that in a real world circuit there are always parasitic resistances that are in parallel to the nominal resistance, their exact value is often not known.
    So you want to keep the resistor much smaller than the parasitics, so that they don't have much influence.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It mostly depends on the impedance of the circuit you are tapping into the RC circuit with. Modern JFet op amps are extremely good.
    There is also the issue of really large electrolytic caps being extremely leaky. This makes them unusable for many applications.
  5. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    One Farad capacitors do exist and they really aren't huge. ;)
  6. atferrari
    Jan 6, 2004
    2,669
    784
    Yes, but, they cannot be used anywhere. Like the more common ones.
