I really appreciated the help given to my on the other side of the forums for a basic servo project I've been working on, but this next issue is something I think is better suited here (I'm quite an amateur at these subject, so please, forgive me!)
To the topic...
I put together a mash up between a small servo and a scrapped RC toy car transmitter/receiver, so I can operate it wirelessly. Connections all work and it operates as far as function is concerned.
My issue, is that the signal strength is considerably weak. I literally have to be within a few inches of the receiver's antenna wire for me to get it to operate. When the signal is close but not close enough, the servo will not operate smoothly
I gutted the transmitter (RC controller) and simply removed the telescoping/non-wire antenna, but the wire that ran from it to the circuit board remains exactly how it was when I took it apart. Same for the receiver antenna wire, which is significantly longer.
So, is there a way to fix this issue? It is not power, as I've swapped out new and old batteries during my tests. Fixing this will pretty much make or break the servo aspect of this project, so I am really in need of assistance from experts on the matter..
Thank you for your time!
-TC
To the topic...
-TC
