RC series circuit
Discussion in 'Homework Help' started by TechnicianEngineer, Dec 5, 2011.
  1. TechnicianEngineer
    Nov 29, 2011
    A series circuit contains R = 150 Ω, and C = 10uf, and connected to a 110 volt source. If the source frequency is 120Hz , find the current flowing through R.
    The answer seems to says it was 0.55A
    SOLUTION:
    Xc = 1/(2pifC) = 132.63 Ω
    Z = √(150^2 + 132.63^2)
    Z = 200.23 Ω
    I = V/Z = 110/200.23 = 0.5494A
    θ = arctan(- 132.63/150)
    θ = -41.48
    Rec(0.5494 < -41.48)
    0.5494 = 0.4116 - 0.3638998j
    where Ir = 0.4116 ===> does not = to the answer key given
  2. crutschow
    Mar 14, 2008
    13,505
    3,378
    You found the answer for the current flow in the circuit as 0.5494A. In a series circuit all the currents are the same. You do not need any further calculations to determine the current in R.
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    I think possibly the OP is expecting the in-phase (or real) component of the current to equal the resistor current. This would only be possible with a parallel circuit.
